push button start.... muahahahaha :evil:
    after driving home from work i decided to go to my girls house. got in the car turned the key and all i got was a click.... WTF????? i checked my battery terminals, checked and clean starter connections, used voltmeter to check all wiring on keyswitch and everythin there was good. turns out a weak selanoid might be my problem because if i bridge the connection with the live terminal the engine turns over like normal. the solution: bridge these two connections with a tiny horn button in the circuit for the switch. the car will (hopefully) start in the following sequence 1. switch on ignition 2. push tiny horn button. seems like a plan??????
    Do it and tell us how it turned out.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      I have a trigger start for my 91 CRX.
        yea i think wikked had a DIY on here. or someone did
          make a DIY w pics
          Formerly 91AccordExR33
          11.68 @ 127mph
          417whp/375wtq
          Sold: 8/2016
            why not hit the starter with a hammer, if it starts u know its a bad one...then just change it instead of trying to ghetto rigg something
            Retro!
            Hater
              the starter is eventually going to go out completely, so just replace it
              if you really want to do a push button start, you will definately need a relay, and yes i do believe there is a diy here
              Members Ride
                that button start thing was a baaaad idea. i returned five different kinda momentary switches to the auto parts store not to mention the waste of money to buy wire. all i had to do was change the freakin selanoid........... ugggghhhhh
                  hehe yea you need a 30 amp relay and you could of went under the column...
                  since u split the wire directly the switch itself couldnt handle the heat.
                  Retro!
                  Hater
                    push button(real way not junk)
                    smoke tires, not drugs.
                      i have push button
                        I have push button start also.
                        Mr.Phil: "FitMoHoesInMyFoDO"
                        Young jeezy:If you ain't talking about money then you ain't talkin bout Shit.
                          Originally posted by slammed4thgen
                          Looks hot on the mustang!
                          But unless you have a wiring problem why would you want a start button?
