Help please!
    Help please!
    My car has had an ongoing issue that is starting to get extremely annoying. I can be going any speed and my car will start sort of stuttering. I'll be trying to accelerate, but my car just won't gain any speed and you can feel it jolting. Then if you floor it, it'll go, but as soon as you let off, it starts doing it again. We were thinking it was maybe my TPS, but I was told that my Check Engine light would come on if that were the case, which it doesn't. We've replaced my distributor,cap, rotor, plugs and wires and that didn't help... Any suggestions?
    -Heather-
    www.myspace.com/mmmpeaches
    www.502streetscene.net
    Check your EGR, EGR Ports, and catalytic converter. Sound like something is clogged somewhere
    F22A1 = Now, NA : Soon, Turbo
    My Member's Thread
    Arcadia Green #14
      vacuum leak, fuel filter bad, clean the fuel system, check timing
      EDIT: i just saw a pic of you. holy shit your a cb7tuner chic. post up more pics. and your car looks flawless.
      miss my turbo cb7
        Thanks guys. I'll check back if it still has issues... And I wish my acorn was flawless. I got hit by a drunk driver in April, so the passenger side rear quarter panel is f*ed and I have no passenger taillight. :-\ My poor car.
        -Heather-
          poor car, but good to see a chick actually trying to diagnose her car... mad props to you
            yea good to see a lady cb7tuner on the site. was wondering if there were any ladies on her not just the moderator. also good to know ur trying to fix ur probs.... stay at it and u will find the solution...good luck.
              I know this thread is over a year old, but I need to bump it... The issue with my car is the same (see OP), but it's gotten REALLY bad, as in it does it all the time now. I didn't have the time or money to mess with my car with I made this thread, but I have to do something now. My CEL has been coming on randomly, so my boyfriend checked the codes and coolant temp sensor and O2 sensor come up. I plan to replace them in the next week or so. Do you think that could be causing the problem? I really want to start cheap to find the issue because I don't have the money to waste. Also, does it vary from car to car whether there are two O2 sensors? I'm not sure if my car has one or two. Thanks for the help!!
              -Heather-
                I owned a Pontiac Sunbird and when the o2 sensor went it would do the same thing you described. I could accelerate up to about thirty ok and once there is would shutter...almost like it was only firing on two/three cylinders. As soon as I replaced it, back to normal! I definately think the o2 sensor would be a simple quick cheap shot at your problem!
                  Hopefully that will fix the problem - it would make me ecstatic!!
                  Can anyone answer the question about the O2 sensors. Do only some cb7's have two? I'm not sure if mine has one or two. I'd like to call and get some prices while I'm at work, so I'll need to know that.
                  -Heather-
                    It's only one O2 in cb'7, it should be right on the header(exhaus pipes that coming out from the engine) between motor and radiator. you'll se wires runnig to it and it looks kinda like spurk plug.
                    The SE accords have them under the car beffore cat.
                      our accords only have one.
                      depending on which engine you have, it could be right there in the exhaust manifold (F22A1) hidden by the heat shield or it could be under the car just slightly after where the two exhaust pipes come into one but before the catalytic converter (F22A4/A6).
                      to see which engine you have theres a small flat area right in front of where your front engine mount is. or look for the radiator hose that is coming from your engine that goes to the top of the radiator. it's right under it.
                        Thanks guys. Hopefully I can get this taken care of this week. I'll update on whether it fixes the problem or not. Cross your fingers for me!
                        -Heather-
                          cool, good luck with it. oh yeah if you do have to get a new o2 sensor, make sure to buy a genuine Honda one because the Bosch ones from the autostores don't work too well in our cars.
                            Ok, thanks for the advice. My boyfriend actually works for Honda, so I get a little discount.
                            -Heather-
                              NGK O2 sensor is not a bad choice as well......
