getting a cb7..that doesn't start..
    Originally posted by rickyduckworth
    well i wasn't there so i only know what you tell me, but if i didn't check it myself, i'd not consider it checked at all.
    just start with the basics.
    if the fuel pump isn't kicking on/priming when the key goes into the "ON" position, then you normally check the relay. if that's ok, then you wanna check the ALL the fuses. pull them and look at them, or check both posts.
    then you wanna check the grounds on the engine (on the thermostat housing and from the valve cover to the frame on the driver's front, and just look around in the engine bay for disconnected wires).
    then the ECU since you can simply swap it really quick and see what happens.
    then you wanna check the fuel pump itself, which isnt' so much fun.
    you can actually find a diagram and check the wires under the dash that come from the pump. that's probably easier if you can locate them properly.
    you're lucky that you can swap parts between cars and check it that way. not that technical but it works.
    check to see if the ground wire on the thermostat is connected RIGHT THE FUCK NOW!!!!!
    Where's the Thermostat housing?
    we were gonna put the ecu from my 91 to the 93
    but it's diffirent model numbers
    can i still swap them ?
    or not they problally fit too
    Ride: 2002 Lexus IS300
      follow the upper radiator hose (the fat hose that comes out of the top of the radiator, almost as fat as my dick) to the engine. it connects to the thermostat housing and there should be 2 bolts that hold that little housing onto the engine. one of those bolts should have a fitting with wires attached to it and those are your ground wires. if they are disconnected, it won't run. if they aren't there, then you gotta find them, should be in the wiring harness somewhere close to that little area.
      and yeah, swap the ecus, won't hurt anything.
      ....and on the 7th day, deevergote rested and called his mom.
        spray some starting fluid or gasoline into the TB while an assistant cranks it. Be LIBERAL with it. If the car starts, then you KNOW its a fuel delivery problem. If it does not, spray some more starting fluid (most people dont get enough in there the first time they do this.) Otherwise, your problem lies elsewhere.
        Disconnect a spark plug wire and stick a screwdriver in there, lay it so its near the block, but not touching (mebe 1cm) and crank away, you should get a nice blue spark.
        Your car only needs 3 things to start, Compression, Spark and Fuel. Take one away and you have nothing. Check your spark 1st, then spray the starting fluid, so as not to inadvertently start a fire (never happened to me, but always makes me nervous. Though a fireball shot out of the TB once while i was messing with timing on a dodge.)
        This should at least get you looking in the right direction, not "Well i THINK its this or that." If you can, do a compression test. If you can get a good compression reading, spark and get it to at least stumble on starting fluid its PROBABLY a deceptively simple problem.
          When was the last time the fuel filter was changed? Just a thought? When was the last time it ran? You should also check under the back seat for any broken connections on the fuel pump. Not really knowledgeable but just throwing stuff out there.
          "I'm a dude playing a dude, disguised as another dude"
          "That if thou shalt confess with thy mouth the Lord Jesus, and shalt believe in thine heart that God hath raised him from the dead, thou shalt be saved."
          Romans 10:9
          ><((((º>
            just my 2 cents, but sounds like maybe your not getting spark. definately check that. Also i would crank the motor with the ignition for a good 20 seconds and then pull one or two of the plugs and check to see if they have fuel on them. in other words, the plugs should look like they are wet. if not, your injectors may not be working right.
            i know you mentioned it, but look again at the fuel relay. pop the case and make sure those two spots aren't burned. really sounds like the relay to me.
            5 months old and already a lady killer
            Dust & Blood (my bro's band)
            http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=921 03410
              he confirmed that the pump wasn't priming when the key was turned on.
                ow fuel filter
                wheres that located isn't that thing near the pgmi thing ?
                and that spraying some fuel or starting spray stuff sounds dangerous
                lol
                i'll try to locate the thermostat ?
                anyone ever have the same problem ?
                  idk man unless my cb7's relay didn't work either but mine is fine
                  so idk
                  i'll trouble shoot it tommorow when i get it
                    ow fuel filter
                    lol
                    check the thermostat ground first. don't spray anything into anything or mess with a fuel filter.
                    if you can't hear that pump priming, then something between your key and the fuel pump isn't working.
                      yea i no
                      something between that
                      so what's in order from key to pump ?
                      ignition then
                      main fuel thing?
                      then pump ? idk
                        yea i no
                        ignition then
                        main fuel thing?
                        then pump ? idk
                        electrical shit.
                        just quit brainstorming and don't worry about it until you check that one little ground. that could easily be your whole problem and would take 2 minutes to fix.
                          electrical shit.
                          so you said it's the hose coming from the radiator towards the motor
                          that you said is as thick as your dick lol
                          but yeah what's it look like ?
                          anyone have a pic for better understanding?
                            i'm kidding man, if my dick was that big around, i'd have something to do on the weekends.
                            it's the biggest hose and it goes to the top of the radiator. right by the radiator cap. follow it to the engine and that part that it clamps onto is the thermostat housing, and the thermostat housing bolts to the engine with 2 bolts, one of which should have 2 small wires bolted under it. those are very crucial ground wires.
                              the big black hose is an upper radiator hose. follow it to your thermostat housing
                                the arrow is pointing to your thermostat housing's ground wires
                                [IMG]http://www.****.com/pics/tstatground.jpg[/IMG]
