getting a cb7..that doesn't start..
    im buying a cb7 93 model for $150 bucks from this dude he knows a little about mechanics but he doesn't know what's wrong
    but he doesn't need it so he's selling it
    i really trust this guy so yeah
    he told me something is wrong probally electrical who knows
    something doesn't pass electricity to the fuel pump
    cuz he test the fuel pump and it works
    tested alternator
    tested ignition
    tested distributor
    tested ecu thing under carpet on passengers side
    tested main fuel relay
    tested like almost everything
    and it still doesn't start
    it cranks but won't start anyone know what's wrong
    btw all fuses are in working condition and all lights and windows work
    so yeah who knows
    im buying the car cuz it's flawless and everything is complete in the car
    nothing missing no dings nothing
    it's a lx 5 speed
    if i can fix this it would be awesome
    but yeah
    anyone know what can be wrong
    thanks
    Ride: 2002 Lexus IS300
    check the fule relay switch ...might need to be replaced its aboput $60 or you can try and sader it yourself...
      Grab it thats a still. Do you have any mechanics in your family that can look at it. Did you look at the fuel injectors, it soulds like something electrical though.
        fule relay is electricl... and @ most Honda drelerships its $60 some are a lil mor and some are a lil less..depends on were you look..but you can also finda a guide online that showas you how to sadrer it ....
          try to post a video while trying to start her
          check the spark plugs and timing
          don't go cazy jumping to ideas start simple compression check her first
          4 door ex-l
            i had a problem like this with a cheap car and it turned out to be simple i think. let me see if i can dig up the old thread
            EDIT:
            couldn't find the thread. i remember it was just like what you mentioned, and i even replaced the fuel pump, traced wires, etc.
            and i have no clue what it ended up being. it was simple and ridiculous though.
              the main fuel relay works
              we put the one from my honda on and it doesn't work
              the sparks plugs and wires are new
              he put them on like 2 months ago
                The Fuel pump works
                He connected it to the battery and it sends fuel through hose
                you know how you turn the key and the fuel pump send the fuel to the engine ..etc
                it doesn't do that
                you hear no noise that indicates fuel pump working but fuel pump works
                and main fuel relay thing works too
                so yeah ?
                any ideas
                  Originally posted by cvc7chris
                  The Fuel pump works
                  it doesn't do that
                  so yeah ?
                  any ideas
                  i'm gonna rack my brain and try to figure out what my problem was. it was just like your's and turned out to be simple after i had done basically everything else.
                  i remember tracing wires between the pump and ecu. try swapping ecus and seeing what it does.
                    yea im giving him my laptop
                    he said if i want it by tommorow morning
                    because he has alot of cars and he was gonna take that one to the
                    junkyard and sell because he has alot of cars and he doesn't want to spend any more money on it
                    so he told me if i wanted it for parts or repair it
                    plus he doesn't have the time to fix it either
                    i'll post pics tommorow
                    asap
                      He actually bought a replacement one at autozone and he put it on and still didn't start
                      but he returned it knowing that the ecu is good
                        there is some reason your fuel pump isn't getting power. could be wiring or the ignition switch.
                        you're also going on a lot of what he tells you he's done. no offense, but sometimes people lie. i'd check everything over again MYSELF and then go from there.
                        try your ecu and try to manually get the pump to kick on so that you KNOW the fuel pump and ecu are good.
                          well i kinda believe him
                          because i was with him when he was doing most of it
                          cuz he lives a few houses down
                          we got the fuel pump to tick
                          he changed ecus
                          because he showed me the new one
                          but he returned it
                          i don't even know where the ignition or nothing like that is
                          so yeah
                          i cranks but doesn't come one
                          alternator works batt. works lights come on perfectly
                          ecus working fuel relay working ignition is suppose to be working he checked it i wasn't there
                          ugh i have no clue
                            how would you try to manually get the pump to kick in anyways?
                            the way we did it was like connecting these wires to the batt and check in front where the gas is suppose to come from and the fuel is delivered to the engine in front
                            but just by turning the key it won't crank
                              he changed ecus
                              but he returned it
                              so yeah
                              ugh i have no clue
                              well i wasn't there so i only know what you tell me, but if i didn't check it myself, i'd not consider it checked at all.
                              just start with the basics.
                              if the fuel pump isn't kicking on/priming when the key goes into the "ON" position, then you normally check the relay. if that's ok, then you wanna check the ALL the fuses. pull them and look at them, or check both posts.
                              then you wanna check the grounds on the engine (on the thermostat housing and from the valve cover to the frame on the driver's front, and just look around in the engine bay for disconnected wires).
                              then the ECU since you can simply swap it really quick and see what happens.
                              then you wanna check the fuel pump itself, which isnt' so much fun.
                              you can actually find a diagram and check the wires under the dash that come from the pump. that's probably easier if you can locate them properly.
                              you're lucky that you can swap parts between cars and check it that way. not that technical but it works.
                              check to see if the ground wire on the thermostat is connected RIGHT THE FUCK NOW!!!!!
