I Have a 90 acoord EX 5 SP I want to know if I get a H22 will it bolt right to my tranny ???
H22 Swap
yes, this answer can be found in the sticky in the swaps section. spoon feeding is for babies not newbs now
My Members Ride Thread
Originally posted by deevergoteYou have to think outside the box to get IN the box!
Originally posted by h22boostyes it will
It's sad that the members with hundreds of posts simply say "search" in the Beginner Forums (I can reply in kind by saying "read the rules!") and that the only real help comes from other Beginners.
But yes, they are correct. The H and F series transmissions are interchangeable. The only issue would be the fact that the gearing would be different. F22 gearing on an H22 means you'll be shifting at redline and still falling short of VTEC... it doesn't take advantage of the H22's powerband as well as the proper transmission. However, it's a good way to get the swap in as cheap as possible, and just get an H22 trans later on! OR, if you want to attempt the expensive task of boosting (turbo) the H22, the F22 transmission's longer gearing is actually a good thing.
The answer to this question HAS been given many, many times.. and is probably in the "sticky" threads. A simple search and a few minutes reading the stickies in the various forums will give you a nice head start! It'll also help you get good answers to your questions. 4 members have replied to this thread, all 4 of them knew the answer to your question... but only two actually replied... probably because those other two have answered the same question a few times, and KNOW the answer is out there!
No question is stupid in the Beginner Forums, but please don't be lazy.
