vibration
    vibration
    when im braking my vibrates like crazi...
    wat couldit be?
    SPYDER CB7S
    ONE CLEAN CB
    warped rotors.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      wheels need to be balanced
      bought from - b-bomb, Davids92Accord
      sold to - Old School, DA92CB7, F22Cb7Rid3r
      ^^ R.I.P. you will be missed
        Originally posted by DarkShadow707
        warped rotors.
        agreed. If it only occurs while braking then chances are you just need to have your rotors turned. I'd pull the off, and take them to autozone and have them turned for free. Many people also put on new pads at at this point to insure the newly turned rotors stay straight. You may also check to see if your wheel/hub bearing are ok. Jack the car up, and try to pull and push the tire while stil on the car. If you have movement thats a good indicator that something is lose, wheel bearings or tie rods or ball joints. Many of those go out together, but its most likely your rotors. I have the same issue right now and Im pretty sure its the rotors. Easy fix though as long as there is enough rotor left to turn them. Keep us posted on what you find.
          If wheels needed to be balanced it would happen accel and decel. Its warped rotors as the rest have covered.
            Whoa! autozone machines rotors? for free? since when? i didn't know they do that, i thought they would sell you their crappy duralast ones first
            member's ride thread
            91 Accord SE 176k
              i didnt kno they turned rotors either.... i thought of the rotors... ill probably replace the rotor and pads...... thnx for da help ill keep u guyz posted.....
              SPYDER CB7S
              ONE CLEAN CB
                if your rotors are still thick , keep em and get it resurfaced. Otherwise replace if you have something nasty
