AC R-134a conversion kit for honda
    my car ac does not work right now it needs charged. thing is our cars come with R-12.
    sooo, does anyone have a honda r-134a conversion kit so i can charge it with r-134? OR does anyone have a box of R-12 wanna sell cheap?
    thanks!
    1991 White Accord LX 5-speed aka Lil' Red
    you can pick up an ac conversion kit at checker or parts america for around 20 or 30 bucks
      for honda? becuse i already picked up a conversion kit from autozone, but it will not work. Honda have a differemt connector some weird one.
      but thanks i will check out those stores if there is any in this area.
        all r12 fittings are the same so the kits they make are usually for a wide range of vehicles the only differences would be the angles of the fittings
        I need a 14b or 16g turbo!
          ??? Anyway I got mine from oreilly or autozone. IF you want to convert to 134A you have to change the reciever drier (cylindrical drier driver side). That is if everything was working properly before and the fittings. The fittings screw on BUT make sure you take off that schrader valve inside the stock r12 valve first. A lot of people making the mistake of screwing the fitting right on top of it and messing it all up. Anyway the 134a kit shouldnt cost much and a new reciever drier is like 50 or so from autozone and such. 134a is also cheaper in the long run.
            hey thanks man
            me and my roomie looked at and we found the drier by the steering pump. but one thing, there is a round like thing that have a cable that leads to the firewall, and we could not figure out what it is. my old white car had that but my roomie's car did not. all three are 1991 lx's. hanyes manual does not show it whatsoever in the pics.
            but it looks pretty easy changing out the drier. once again thanks!
              the rock like thing, i believe you are talking about is part of the cruise control system, i may be wrong but its a vacum actuator. if your cruise don't work than you could just toss it or sell it. or just move it out of the way so you can access the drier.
              My Members Ride Thread
                now u mention it my cruise does not work, light comes on and everything. thing thing looks like a turbo sorta, but nto really. there is tubes leading to the intake manifold tho. but it looks easy taking it off two bolts the whole braket comes right off.
                  Yea thats your cruise control. Its two 10mm bolts and a cable that goes to the pedal. To get it off the firewall you just twist it and it should pop out.
                    sweet! k yeah my cruise don't work, the light comes on and thats it. so i might as well replace that too.
                    alright thanks guys!
                      checked fuses ? my crusie cntrl didnt work for over a year .... lights still came one.... after all that it turned out to be a fuse
                      Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
                      But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
                        ha no kiddin? k i kinda thought the fuse does the whole thing so if no light workie then no nothing. lol k cool gotta check that. thanks!
