just changed head gasket now burning coolant
    does this look ok?
      im having alot of ppl telling me the head is cracked where would the crack be?
      i also just did a leak down all came out moderate all around 50 didnt see any bubbles in the radiator or any oil coming from the head gasket so what can it be?
      all my lines looks to be in the right place
        help somebody!!!
          here is a pic of the smoke with the water spot
          pic of the smoke
            I have to agree with Bruno. You need to have that head checked to see if its straight. Also replace that IM gasket. How are you torquing down the head bolts?
              i just got the head resurfaced (mill) down to .005 so the head is straight also i bought a new IM gasket and im torquing down the head bolts with a torque wrench. im going to get the head pressure tested so there goes another $50
                before or after you removed the head?
                Did you clean the mating surfaces before re-installing the head?
                It's actually pretty hard to warp a head if you take it off with the engine completely cooled, and in the correct order.
                I've taken off my head like 3 times and everything is a-ok. I checked it with a straight edge everytime.
                  the head was resurfaced the 3rd time i took it off and i really didnt have to get it resurfaced because my machine guy said it wasnt that bad and the new head gasket should of tooken care of it but just to make sure he milled it anyways. now i've asked him to pressure test it to see if there is any cracks and if there isnt any cracks in the head its gotta be the block right?
                    Did you drain your coolant before taking the head off? Did you clean the inside of the cylinder before putting the head back on? Looks like theres some coolant on your walls.
                      is the drain on the back of the block? isnt there 2?
                        There is a drain on the back of the block, right below the water pipe, and to the right of the water pump. Its a big bolt looking plug I believe.
                          that big drain plug is really hard to get off i stop trying after a few tries.
                          got some more pics of the coolant/water problem
                          here is a pic of the water inside the head on the exhaust side
                          but here are the exhaust side head bolts normal no milkshake looking like
                          here are the head bolts from the intake side only 4 of them are milk shake looking but the middle bolt is fine
