How do you know?
    How do you know?
    How do you know without taking off the head that you have a broken valve?
    no compression in that cylinder
    Originally posted by kc8enb07
    does it come w/ jdm trash? they better throw away gold in it
      x2. the car will barely start. even if it does, you'll hear it.
      miss my turbo cb7
        Well, The car starts. It's just when it first starts it sounds good, then, when I set the idle to where it's supposed to be, it bogs down a lot, as if it doesn't have enough power, and i took it for a test drive, it drives, it's just it jerks into gears, and the exhaust is not coming out smoothly it's coming out rough, and the exhaust pipe shakes alot. What is everybody's thoughts?
          take off the cylinder head man.
          miss my turbo cb7
            No need to pull off the head...Save yourself some trouble get a compression tester and compression test the cylinder. Its not worth tearing anything apart if you arent sure if that part is flawed. How is your basic tune up. Exhaust flow is supposed to come out puff puff puff not a smooth flow. If you are missing thats a different story.
              you could have an ignition problem...timing off, bad plugs, wires, cap and rotor. I say start replacing cheap stuff first then work up to more expensive. but difinitely get a compression check.
              H22 Swapped
                So sunday, me and my dad are taking off the head. I will keep everybody updated.
                  ummmmmmmmmm
                  or don't listen to what everyone told you!!!!!!!!!
                  I think your wasting time an money. please, do a compression check and check your timing as well, im leaning towards timing by the way you describe it.
                  5 months old and already a lady killer
                  Dust & Blood (my bro's band)
                  http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=921 03410
                    can't you rent one of those really cool cameras (like they use for laproscopic surgeries...and colonoscopies) but for the car? To buy they are pretty pricey...but I think you can rent one.
                    BUT...I agree with previous posters...leak test...and compression check...remember...do all dry tests first...then follow with a wet test.
                    ____
