Transmission problem?
    First things first, when I start my car, when i hit the brake pedal to switch gears I don't hear that little click noise.
    Now when I start the car the d4 light is on. when this first started, that little clicking noise as if I hit the brake pedal was having a seizure, then it stopped and the light has stayed steady since. at first(this morning) it was going to the rhythm of the click of the brake pedal(which I wasn't touching)
    When I'm in d4, No matter if I barely hit the pedal or floor it, it hits 2,400 rpms and barely goes anywhere, it acts as if the e-brake is on. THen when I hit 50, after taking about 25 seconds. even if I floor it, the rpms doesn't jump, it's not switching gears in d4. You know how you go a little bit, it goes a little, gas pedal half way, it jumps to 4. Floor it and it jumps to 6 and switches.
    So anyways, I put it in number 1 and drive it like a manual, and when I switch to 2, it doesn't shift. but then when I put it in d3, it shifts, and then into d4 it doesn't. It's like I only have two gears. So all today I was driving (so that I could keep a good acceleration and not get beeped at ) throw it in 1st, wait til about 5000 and throw it into d3.
    What's wrong?
    And of course off-hand this is tranmission. My fluid is fine, brand new and not brown and doesn't smell burnt and full.
    Now is this the actual transmission or a linkage problem?
    Is there any quick way to fix it, kinda like bang the starter kind of thing to make it last for a few days until your ready to switch the tranny.
    No longer have a cb7.
    V6 POOOWAAAA
    lol, a buick.
    I vote VSS or TCU
    wat?
      VSS?
      TCU, that's the ecu but for transmission, where's that located?
      V6 POOOWAAAA
      lol, a buick.
        well im bringing it around to get it checked out today.
        V6 POOOWAAAA
        lol, a buick.
          I was having a similar problem. So I repaired the main relay. And it seemed to fix it for a few days. Check your solenoids, maybe the one on the passenger side.
          "My FOR SALE thread - Click here"
          MEMBERS RIDE
          99 SILVERADO
          WHEEL FLIP
            Well I brought it somewhere and there going to do a rebuild on my transmission something with the solenoids or somthin is gone anyways its gonna be about 1200
            V6 POOOWAAAA
            lol, a buick.
              Try a junkyard tcu first
              also you could get a used in good condition for 1200
              wat?
                Jump that TCU Code before taking shit apart and replacing.
                  drew12000 agrees!
                  MEMBERS RIDE
                  99 SILVERADO
                  WHEEL FLIP
                    damn now people reply its too late
                    V6 POOOWAAAA
                    lol, a buick.
                      hey man I hope you don't mind but I am having a similar problem with my tranny but the difference is that my tranny work ok for a while but when I start hitting the higher speeds and the rolling hills the Sport light on the dashboard starts to blink. At a stop light the tranny starts at 2nd and then goes to 4th... totally skipping the 3rd gear. Needless to say on a busy highway is a real pain in the neck. Can anybody help a guy out with some advice!?!
                        hey jayrob333 i had the same problem on my 92 accord i think the part is called shift solenoid not 100 percent sure theres two a & b. ok lift up your hood! standing in front of your car look on the tranny theres two round things on the left side of the front motor mount theres two more about three inches below that change the two sets and you should be back to normal
                          thanks 9accord3... i will try that
                            I wouldnt say its a shift solenoid problem...There is another solenoid inside the center console. Over there there is another part I forgot the name the brake switch sends it a signal and it does that *click* sound you mention. That way it releases the lever. I forgot what that part was called.
                              its your TCU. Open it up and look for a burnt resistor. Thats your problem.
                              replace TCU--Done.
                              Seattle Silver crew #5
                              Member of the Midwest Car Club.
                              ..........2004 accord ex v6 - J30A4.......................... 91 accord ex - JDM H22A -- Long gone...
