Originally posted by JDM_accordf22a4
Revving to 9500rpm puts a hell of a lot of strain on an NA motor. The compressive force of turbo puts a good strain on the pistons. The heat of the turbo also takes a toll on the internals of an engine. Put that together, and you're asking for trouble! Not saying it isn't possible... but you'd need to learn what you're doing, and do it right.
As for high compression turbo, it's more than doable. Not recommended for the beginner, but doable. I wouldn't risk it myself! Low compression isn't necessary for turbo, it just increases the amount of room you have for error. Bump compression into the 12s, you had better know how to tune it perfectly! If you're wrong and try to run the motor... boom.
