h23 thermostat housing
    anyone have a picture of the h23 thermost housing? i am trying to do the intake manfold swap but there is no place for my thermostat housing to bolt up, it just has 3 small coolont lines for a small hose. i will probally end up modifying my wter pipe. but it by nice to know where those hoses go to and also where the thermostat is.... thanks in advance
    you can use your F22 thermostat housing with this swap.
    you do not have to modify the water pipe in any way.
    as far as 'not having a place to bolt up' -it is on the left, (looking at it from the front) exactly how your old one was.
    Originally posted by kc8enb07
    does it come w/ jdm trash? they better throw away gold in it
      thats what i thought i will double check that when i get home. but this is for the f22b1 so i dont think the f22 thermostat housing will fit. there was already alot of modification needed like the port matching to the head....and it is still in tha werx, and i may actually get it going with the new intake manifold which i have yet to see anyone successfully do, thanx cb7
        just checked that and you can only do that if you have a f22a, f22b engines use a completely different thermostat housing. and i need to do some modificationz
        thanx
          oh no wonder...you got an F22B1!
          Yea I think someone on hondatech made a write up on it...
          cool beans lol
            okay i can see where it goes, can you please tell me....does it actually bolt op to a water port? or does it just mount to the manifold and use the coolant hoses to connect to other things?
