F22b1 Will The Intake Manifold Of A F22b Fit?
    F22B1 WILL THE INTAKE MANIFOLD OF A F22B FIT?
    93 ACCORD F22B DOHC 190 wHP WHIT OUT 50 SHOT NITROUS CUSTOM PAINT SHAVED DORS 3" DROP DUAL EXHAUST 02' MUSTANG TAIL LIGTHS
    if you have a F22B1, and want to put a JDM F22B / H23 intake manifold on it,
    It will not fit.
    Originally posted by kc8enb07
    does it come w/ jdm trash? they better throw away gold in it
      Technically speaking it CAN fit the amount of modification required to make it fit makes it not worth it.
        can someone elaborate ? i thought the H23 IM did fit any F22?
          It does... on an F22a. I don't know about the b's.
          Click for my ride thread.
            damn cuz i got one coming in the mail
              H23/A6 manifolds fit on any F22A or JDM F22B (as i recall similar to h23). IT WILL NOT FIT F22B1/2 unless you modify it. The write up is somewhere on accordinglydone or accordtuner.
                the f22b1 & 2 heads are completely different from the f22a
                .............................-----------------93 Ex Coupe[/COLOR]-----------------
                My CD7
                  okay but hopefully i can still use the plenum
                    lol you cant use the plenum either. sorry bro.
                      OK COOOOOL THANKS THAT HELPS
                        AND if you read my post search accordingly done and accordtuner one of those forums has a writeup on putting an h23 IM on a b1...And I already said it requires more modification than its worth if you read that...
                          thanx i found it on accordinglydone. i am willing to do the modification / cutting. but i dont see why he needed to re stud his intake manifold he said he was usung a f23 rail on the h23 manifold. he relocated fuel line anyway so im thinking just to use the h23 fuel rail/ injectors(anyone know if they are a bigger cc injecter?) and he didnt have any way to use the secondary butterfly, you need a h23 ecu to controll them but that ecu does not do vtec....best to just remove them i think, also there is an issue with the fitting of the thermostat housing bolting to the b1 head. thanks for the info its ALOT of work for a half decent mod. from what i hear the ports are not a perfect match so it pretty much warrants a port matched head with the new runners. i promise to do the write up if i pursue this. i have a complete f22b1 motor and a complete f23 manifold and a extra f22b2 manifold so i think i can figure this one out. and probally no gains, but mad vtek right?
                          h23 manifold writeup: http://www.accordinglydone.com/forum...ad.php?t=11176
                            negative on that the intake wont change a thing cept mabye the sound might get deeper, the vtec still sux on the f22b1 its econo vtec not POWA vtec lol like on the h22
                            PSN ID's:Tidashoni
                            1992 Accord EX Coupe
                            My FS Thread
                            Not so DD 2013 Subaru Impreza WRX STI
                            Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
