i have a f22 b2,i really cant seem to find the DOHC f22 locally, and the h23 head swap seems difficult.... i was thinkin i can do the b1 headswap so i get vtec after i get a new ecu also. this sound like a good mod? is there a better candidate to pick up some extra horse power?
head swap
no shit....okay thanx i have been avoiding the whold turbo thing....my friend once had a b1 head port and polished that had good really pull when the vtec kicked in....i just know that the F22 has more potential then what it is at right now even if it was all N/A. cuz the h22 has so MUCH more power with almost the same displacement
I have a f22b1 swap, the complete swap. It seems like it has less power than my original f22a1 with both on's. Stick with the f22a, thats what i'm doing. Later this month or begining of next month, I am pulling my f22b1 and doing a water pump/ timing job and dropping it in to my wifes car. I'm then pulling her f22a6 for rebuild and partial build to drop in my accord.
Headswaps aren't a great idea anyway. And honestly, if you don't know enough about the particular heads themselves, then doing a swap would be damn near impossible.
The F22B DOHC head is a decent choice. The H22 head sounds nice, but you'd have to remember that you'd be putting it on a block with lower compression and a lower redline (well, supposedly they can handle it... but I wouldn't risk it). The F22B1 head is garbage.
Honestly, the F22A6 head is a very good head.
People are so quick to assume that the motor that comes in their car is worthless.
If you want to swap, swap an entire motor.
Originally posted by deevergoteHeadswaps aren't a great idea anyway.
There is absolutely nothing that can go wrong if installed right.
Saying that the head is not meant to be on the block is bullshit.
Honda made the F22B dohc, f22a block with an h23 head.
You can use the same gasket, same studs. The valves won't hit the head unless you mill an insane amount.
Any head swap that has gone wrong was because of user error.
Don't rev the piss out of the engine. Don't starve it of oil. Don't add too much timing.
Those are keys in maintaining frankensteins and well...any f22. F22's don't like timing, period.
Look at the countless of ls/vtec going around making insane power.
head swaps are a great idea for cheap power.
Originally posted by d112crzyThere is absolutely nothing that can go wrong if installed right.
If you are able to do it right, you will understand how the engines work, and what exactly you'll be changing. If you have to ask what heads are good, the chances of you getting it right are slim.
There's nothing wrong with turbo. There's nothing wrong with nitrous. There's nothing wrong with twincharging. However, you have to do it RIGHT.
The more complicated you make something, the greater your chances are of screwing it up. The F22A head is perfectly fine for any application. Swapping over another head gives no significant benefit over an entire motor. It's not an easy way to gain horsepower. An F22B DOHC headswap might get you 20hp. It'll cost you $500 or more, on average (200 for the head, 100 for a chipped ecu running a basemap or an approximate tune, 200 for gaskets, seals, fluids, and belts). For the same price, you can get twice the horsepower with turbo, and retain about the same reliability and risk.
Check out the technical and performance sections over the years... see how often people actually "do it right". It's not often.
For the same price, you can get twice the horsepower with turbo, and retain about the same reliability and risk.My Members' Ride Thread - It's a marathon build, not a sprint. But keep me honest on the update frequency!
*Note this is not a flame to what Deevergote said* I respect this man very highly
when I had the h23 headswap, done it in april, and literally drove it everyday (to school and work), made two trips to charlotte n.c., several trips to atlanta. put about 20k on it, there was nothing wrong with it when i pulled it out.... just got the h22 for a good deal, otherwise i was going to stick with it...
i gotta tell you from my expirience, my headswap was GREAT while it lasted(till i started acting stupid ), all i had was the head milled, I/H/E, underdrive pulley, IM phenolic spacer and smoothened ports and boy was that shit pulling like a bat out of hell on stock pt6!
like mentioned previously, when done CORRECTLY, the swap is more than worth it, definite noticable gains and greater opportunity for more power from the amount of money invested
THEN: 1993 Accord 10th Ann. Ed.---------------------- NOW: 1996 Accord EX
My Ride thread
Flickr
Originally posted by d112crzyAnd it can only get better. That's the best part.
All I gotta really say is:
People of cb7tuner, this AUTO is NOT a joke. It has impressed ME, the hater of auto's.
