my EGR valve
    my EGR valve
    Ok when my car runs for a while my check engine light comes on. I check the code it was 12 that is the EGR Valve. But if I turn the car off and then turn it back on the check engine light does not come on. Now iam wondering if i don't replace it what is the worst that can happen i plan on replacing it thought i just want to know what will happen and what is it for in the first place.
    did you try cleaning your EGR valve?? is EXTREMELY EASY --- compared to the ports.
    i cleaned my EGR Valve in about 20-30mins [incl. removing, cleaning and re-installing]
    Member's Page:: Coming Soon
      no didn't try that im going to do it tomorrow no time today I hope it works.
        i also recommend cleaning it, it could be clogged w/ a lot of build up which restricts it from doing what it's supposed to do
        if case comes worst, i recommend deep cleaning your ports(drilling, cleaning, and re-sealing) not necessarily what it'll come down to but just a thought
        My Ride thread
        Flickr
        Originally posted by d112crzy
        And it can only get better. That's the best part.
        All I gotta really say is:
          What does the EGR valve do?
            so its that easy to clean a egr cause i wanted to do that what do i use to clean it
            UNDERGROUND SOCIETY
            NEW COUPE MEMBERS RIDE THREAD COMMING SOON
              it's on of the main parts of the emissions system on your car....
              it recirculates some of the exhaust gases back into your intake to lower emissions...
              My Ride thread
              Flickr
                that easy?? yes
                2 bolts, unclip the power, disconnect 1 hose and lift up. extremely easy
                is like pumping gas in your car - that easy
                  Well in my experiences when you get an egr code then shut the car off and the code goes away its the egr failing what happens is inside the egr is a valve that operates off of vacuum to allow air to recirculate well in your case your valve is not holding vacuum when it should you could pull it off and clean it which might buy you a day, a week, a month you never know when I had the same problem I cleaned mine and it lasted about 2 days. So its up to you if you dont mind doing twice by all means go ahead. Just my .02
                  I need a 14b or 16g turbo!
                    I figured it out today the first time i really looked at it the hose was un hooked so i hooked it back and no more check light Thanks alot.
                      I got a used one for sale. If you need it i could let it go for cheap plus shipping!
                        I didnt have a check engine code 12 untill i cleaned it. Then it started trippin on me. Are we supposed to use honda bond or something for the gasket? Right now I have it with no power and un vacuum plugged.
