ok recently I've been having trouble with my blower motor not working, I believe it's binding but I can't seem to find out why. The first time it stopped I took it to the shop and all they did was take off the bottom intake peice and it started to work again. The second time it happened I took off the cover and searched around in there to see if it was binding or something, but everything I messed with was tight and not causing any problems. Then I checked it out after I put the cover on it and it worked. Now the wierd thing is whenever it stops working now I just hit the bottom cover and it will start working again ... I notice that everytime it stops working is when it's not running, like if the car's off, or if I have the fan turned off. Could it be something with the bearings or is there something I'm not seeing?
any help is appreciated! Thanks!
