Check Engine light on....then went off?
    Okay, today when i was coming back from ASU, I was going on the freeway at around 70mph steady and all of a sudden the check engine light came on and stayed on until i parked and shut my car off. About 10 min. later when I was all finished with what I needed to do I got back in my car and drove home. But the light didn't come again and I even went back on the freeway and then got off but it still didn't come on. So what i'm wondering is, is this a sign of something going bad somewhere? My car didn't drive any different then normal when this came on so???? idk whats going on. It was at 4pm, the hottest part of the day if that has anything to do with it. I was going to get it scanned, but since its not on anymore will it still throw a flag saying something's wrong on a scanner? help please..
    If you had a light and didn't reset the ECU, you should still be able to pull the code. I don't know about a a scanner, but you can do it the old fashioned way.
      usually code 41 does that. usually nothing to worry about either. it's a ghost code of sorts.
      "As far as the prog references go, we embrace them. However, we would prefer our new moniker, which is a Mulligan stew of progressive rock, Bulgarian folk metal, rock ’n’ roll, ’80s disco and Christian rap that we like to call Munge." (Maynard James Keenan cited in Boston Herald, 2006)
        so does code 41 mean my 02 sensor might be taking a crap? cause' i havn't yet replaced that part since i've owned the car for about 50K miles/4 yrs
          well, not really. every time i've gotten it, nothing changed except the light popped on. once i just swapped ecus with one i had laying around and it never came back, another time i just reset the ecu and it never came back
            well, a lot of times a light comes on if you dont put the gas cap on all the way after refilling. Maybe the light came on and off in between you filling up? Just throwing it out there.
              just pull the code and find out then take it from there
              ...adjust accordingly
