Help Me!!!
    Help Me!!!
    okay, so i got the dreaded seatbelt light blinking and beeping thing going on with my car so i took it to the honda dealership to get it fixed because some of you guys said that all seatbelt related issues are under lifetime warranty.....its not, so they told me what the issues could be, one being the door lock actuator, the other being the seatbelt ECM and they are both expensive as hell so i bought the actuator off ebay and am gonna do it myself which brings me tooo.........so
    how in the hell do i take the circled dealy apart, its the arm off the actuator that threads directly into the outside door handle, any help would be MUCH MUCH appreciated, thanks
    ZING!
    MY RIDE
    -=HondaSpace=-
    Yank it all and swap in some 92-93 belts
    Then find the wire that goes to the seatbelt light and snip it. Do you really need your dashboard to tell you that you aren't wearing your seatbelt? That is the stupidest light ever.
      sounds great but i dont have the funds or parts to do that today, but....i do have the part to fix the issue today if i could only get that piece apart
      ZING!
      MY RIDE
      -=HondaSpace=-
        Hmm...ok..well this is the thing...i have a coupe..and it does that...but i realized that if u slide ur seat back..it turns off..yup..simple as that..cuz if the seat is pulled all the way front...it blinks on mines..but if i slide it back all the way..it stops...try it..
          i had a similar problem working on a friend's handle, what i did was i loosened the 3 screw bolts on the latch on the side of the door and let it hang inside so i had just enough slack to pop the handle out and spin that threaded bit out. also you will want to mark the thread or at least take note where you need to readjust later.
          come to think of it, i slightly remeber getting it off, looking at it and laughing at how simple it could have been to get off if i could only see that other side.
          Is God willing to prevent evil, but not able? Then he is not omnipotent. Is he able, but not willing? then he is malevolent. Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?- Epicurus
            thanks guys, i'll give that stuff a try
            ZING!
            MY RIDE
            -=HondaSpace=-
              it would be easier to pull the gauge cluster, remove that bulb and forget about it.
              "As far as the prog references go, we embrace them. However, we would prefer our new moniker, which is a Mulligan stew of progressive rock, Bulgarian folk metal, rock ’n’ roll, ’80s disco and Christian rap that we like to call Munge." (Maynard James Keenan cited in Boston Herald, 2006)
                yeah, thats both easy and cheap, BUT my seatbelt stays in the forward position and wont retract, i have to do it manually and, its a bitch to do everytime i get out of the car. sooo i have got to get it fixed, i have figured out the actuator isn't the problem now, so i'm off to buy a newish seatbelt ecm. plus its not just the light that blinks the little speaker that beeps when you turn on the ignition beeps 24/7.
                ZING!
                MY RIDE
                -=HondaSpace=-
