Car leaks coolant
    Car leaks coolant
    I recently changed my upper and lower radiator hose's along with a T-stat refilled coolant resivor made sure all hose's are tight but now im leaking through radiator cap do I need new radiator cap
    NEW CB
    old Darkcloud : 1990 Accord EX MRT
    new
    DARKCLOUD : 90 ACCORD EX MRT
    That could solve the problem. Get a 14 lb. one instead of the stock 13, and see if it still leaks.
    91 lx h22a
    Member's Ride Thread
    bought from: xkjnboix, new_beginnings
      radiator caps aren't supposed to leak. you got it twisted on tight? you have to push down and give it another 1/4 turn when it "feels" like it's on there.
      and there is no point in getting a 14 over a 13 unless you just want to. out of the 10 or so accords i've had, the 13 did it's job on all of them. it's up to you but no need to spend any real time looking for it.
      "As far as the prog references go, we embrace them. However, we would prefer our new moniker, which is a Mulligan stew of progressive rock, Bulgarian folk metal, rock ’n’ roll, ’80s disco and Christian rap that we like to call Munge." (Maynard James Keenan cited in Boston Herald, 2006)
        OK I bought radiator cap and I have a new problem i go through coolant about 3 times a week and i dont drive it hard what's the problem.
        NEW CB
        new
          You're still leaking somewhere if thats the case, if its not visible, possible blown head gasket (?)
            Busted water pump thats what happened to me
              had a problem like this. check the heater inlet hose. its kinda under the dizzy. my hose was going bad and got a hole right by the clamp.
              bought from - b-bomb, Davids92Accord
              sold to - Old School, DA92CB7, F22Cb7Rid3r
              ^^ R.I.P. you will be missed
