has any one had a prolm on the engine cooling temp sensor
    has anyone had a prolm on the enginecooling temp sensor b 4, i have a chek engine light , and it reads engine cooling temp sensor ,code 6 on my h22 accord please help thank you
    undefined
    Well you have 3 of them. ONe on the tstat, front neck, and toward the middle head area. One of them is bad. All i remember one is for the fan, one is for the temp gauge forgot what the othe was.
      No, you only have one engine coolant temperature sensor. Only one sensor gives feedback to the ecu.
      The sending unit next to the ect feeds a signal to the gauge, the thermo switch on the thermostat housing is just that. A switch that closes the circuit when it gets a signal from ecu.
      The ECTS is right under the distrubutor. Its plugs into the cylinder head, it has a green plug on the wires that connect to it. Thats your problem. replace it. Autozone has em allday long.
        thank you guys 4 the infm
        undefined
