Heatshield
    Heatshield
    I've been running my 93 without an exhaust heatshield from before i even owned the car (My dad took it off shortly after they bought the car). I'm pondering whether or not to put it back on, it's still lying around somewheres, maybe I'll paint it first. Anyways, Will it really make a HUGE difference in performance or economy whether it's installed or not?
    (New sig in the works )
    the only thing it would do is bring down engine bay temperatures. if you have a short ram, hot air = potentially less hp.
      That's exactly what I was thinking, We initially removed the shield when it had a full Cold-Air intake, now it's cut down to a Short-Ram (I live in Canada, Lot's of rain, lots of snow, not a great combo with C.A.) Hmmm, I'll have to go hunt down the shield sometime soon
        if you paint it with a high heat 1200 degree paint, it should work even better too
          Right on, thanks man
            Aside from losing hp with a short ram (which takes air from the engine bay), the heat can damage any wiring under the hood over time.
            Heat is ALWAYS a bad thing with cars. Do everything you can to limit the amount of heat that your parts are subjected to.
              Hey deevergote,
              if you ran your ram air, shouldn't the intake for that be sticking out of the front of the car and getting outside air rammed in? Or are we talking two completely different designs?
              ____
                You're talking ram air which outside air is forced into the intake by either a scoop or the intake sticking directly out of the hood. We're talking short ram, basically a regular intake with shorter tubing and a filter. I'm assuming that's what your question was??
                  SRI sits inside the engine bay which equals warmer air getting sucked in. On the other hand a CAI which goes down usually behind the passenger side fender is taking in more cold air from the outside. That's the 2 options they both have benefits and they both have their downfalls as well
                  SOLD!!
                  Boosted H22
                  375whp 298 ft/lbs at 15psi
                    exactly my question...may post more info later...right now I'm meddling with my two cars...
                    ____
                      You could do your heat shield up right and polish it like TypeG... If you haven't seen hid car, look him up!
                      Talk about the bling factor....LOL
                      I have mine painted with 1200 degree paint, looks nice, and has lasted thus far!
                        if you got the heat shield off and want to lower engine bay temps.. just wrap the header !!!
                        Originally posted by Devergote
                        A CB7 with an H22, a clean paintjob, HIDs with a projector retrofit, some nice wheels, and a mild drop on H&R Sport springs and Koni Yellow shocks... that's the perfect car. I'd be happy with that for the rest of my life.
                          Yes you should ALWAYS wrap it up...be safe guys...and gals...
                          ____
                            Be aware that header wrap keeps the heat in. Metal reacts to high heat. I have yet to see it happen, but it's a good possibility that header wrap will cause premature cracking.
                            The good thing is that the headers that are most likely to crack are usually the cheapies... so you can't really expect them to last anyway!
                              Yea the heat shield may not be all that appealing but its strongly recommended you have one. Try to get one that is chrome to make it look better if your worried about looks.
                              1991 Accord Ex F22a4 Daily Driver
                              1992 Acura Integra LS B18c swap
                              1994 Civic Dx Gsr swap
