Okay i have and oil leek and im confused about it .. see at first i thought it waz my oil pan but i had my uncle look it over and he told me its not my oil pan..and that i need to take my timing cover off and take a look there..also i waz told to chack and maybe chang my oil pressure sensor...anyone have any idea.. also whats the cheapest cat to find for my 92' ex? on thats cheep but is not ganna sufficat my car!
oil leek (Need Help)
Im glad you posted this. I have a oil leak and im gettin pissed. now i know what to look over. its comin from behind the oil pan in the back i can feel it.
we'll c tomm0rrow**Blk Housed Slut Crew Member #1**
welcome To Cb7tuner.com**Blk Housed Slut Crew Member #1**
it could be leaking from the oil filter housing, even though its tight, mine was leaking from a seal behind there, not from the oil filter itself. And as for oil, Mobil 1 came out with this Full Synthetic High Mileage oil i'm gonna try next. Its synthetic, which cuts frictions and gives more power, yet saves all your seals from leaking. so I'll see what that does. You can find a 5 qt jug of it at Walmart for about 20 bucks.
member's ride thread
91 Accord SE 176k
nah...if the oil is coming from the driver side....then he needs to check his (camseal...balance shaft seal...front main ...and or Valve cover.).
if its coming from the center...(Valve cover...oil filter seal...oil pressure unit)...
if its coming from the left..."Passenger side"
he needs to check the ( Dist. O ring.....Valve cover...and if its wet around the boarder between the engine and tranny...he needs to check the Rear main seal ) ** need to take the tranny out
NOTE: he said his dad already checked the Oil pan Gasket and that checked out ok!
DING DING DING...if its a Manual..check your hydraulic lines....and check your Steering gear ( rack and pinion )Last edited by SN2BH22CB7; 08-21-2007, 11:33 PM.92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
no one else said it but check to make sure the rear balance shaft access bolt isnt missing. if its still there ignore this maybe someone else can use this info.Last edited by 91ex2dr5spdCB7; 08-22-2007, 02:07 AM.
That sensor they are talking about...is most likely the one RIGHT ABOVE your oil filter...mine leaked for a bit and would drip past my oil filter and right onto my exhaust...I was about to freak out one day I saw smoke and looked and saw oil on the oil filter...but it was just that little sensor.
It's REALLY easy to get to with the intake manifold off...in fact that's the best way to see it...but man what a pain in the ass...you can get to it from below but you'll have to take off the oil filter.
Aside from that the other posts here are right on!____
I use the mobil 1 synthetic high miliage, every 3k miles. I had and oil leak but, i put this stuff called tx-7 in it every 20k miles and i hardly leak any oil. I work at a jiffy lube so i get all my shit for free
TX-7 link
http://www.polydyn.com/tx7.htm
i checked mine today and its comin from the upper tanny pan, and between the motor. if i go under the car i can see it. i put jb weld. didnt work, some oil is come from my fly wheel area aslo
its motor oil i can tell cuz i put fresh oil and it came out fresh lookin**Blk Housed Slut Crew Member #1**
Originally posted by F20A CB7Im glad you posted this. I have a oil leak and im gettin pissed. now i know what to look over. its coming from behind the oil pan in the back i can feel it.
we'll c tomm0rrow
ya its not power steerin its motor oil. o dam i dunno wtf 2 do. its where i said it was at. i hope it aint a tranny rear seal**Blk Housed Slut Crew Member #1**
Originally posted by F20A CB7i checked mine today and its comin from the upper tanny pan, and between the motor. if i go under the car i can see it. i put jb weld. didnt work, some oil is come from my fly wheel area aslo
rear main seal! like I said before .....oil wet spot between your engine and tranny. ( rear main seal )
change it ASAP!!
while you're doing that rear seal...might as well replace the flywheel and clutch....( 9 out of 10...your clutch disc and flywheel are glazed by the oil )
so Id take the time..WHILE the tranny is out..to replace with NEW parts!
( seal...flywheel..and clutch )
now..if you can...see if you can get that flywheel resurfaced! ( that MIGHT help )
NOTE: the more you drive it with that busted seal...the more damage you'll do to the flywheel and clutch disc surface. what wil happen is...you'll start noticing SLIPPAGE because the clutch can't grasp the flywheel because its now glazed to the point to where...its like trying to catch grip on Ice from doing a 180 ( damn near impossible )
so....change that seal ASAPLast edited by SN2BH22CB7; 08-24-2007, 03:56 PM.92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
MR Thread:
