Tension Alternator Belt Correctly?
    I'm about to replace the brushes on my alternator, which is a pretty straightforward process, using the DIY and my Haynes. However, the instructions on re-tensioning the belt are lacking.
    Do I really just re-bolt the alternator in place, and then adjust the tension bolt until the belt has 1/2 inch of deflection? What happens if the belt is too loose, or too tight?
    too tight you can prematurely wear out the alternator bearings. too lose your belt will slip when you load the electrical system. setting the belt deflection isnt hard at all. always err on the side of caution and go looser, and re-tighten accordingly if you need to. if i install an alt belt in the summer, i 80% of the time, have to give it an adjustment when the cold weather starts setting in.
      your going to feel it. tighten then check the belt, and tighten and check the belt. thats what i do.
      miss my turbo cb7
        They way i check is if you cant twist the belt past 180 degrees your set. Also you can feel it as mentioned. Personally you will know when its too tight at least I do. If its too loose the worse its gonna do is squeal and all you do is retighten it a bit.
          That's an interesting idea. You're suggesting that if I'm looking at the belt from the top and the smooth side is 12 o'clock, if try to twist to the right and left - if the toothed side rotates all the way over (to 12 o'clock) then it's too loose?
          cool, thanks.
            And just to be clear, I tighten the two other bolts, and then use the adjustment bolt at the bottom of the alternator to set the belt?
              If I recall correctly, the last bolt to tighten is the one that sits inside the big adjustment gap.
              ...adjust accordingly
                12 and 14mm bolts have to be loose to set the tension when you get it just right thats when you tighten all of them up.
