First off - Sorry about this many threads. This should be the last technical thing i get into for a while.
On my 90, i have R134 in the lines (woot) and the AC unit itself seeems to be making a decent ammount of noise, Now, i dont know if its just the pulley, or the actuall unit internally, I sprayed a bit of Weasel Pis (WD-40) on the pulley where the bearing should be, and it didnt make a difference, Are they sealed pressed in bearings that you cant remove from the unit, or can i pop off the belt and use a pully remover and hope that the bearing comes with it?
Thanks,
-JS
_edit_
Also, if i have to replace this thing, will i have to switch to the new freeon? Or can some shops in canada still do 134 refills?
Thanks,
-JS
_edit_
