Torque spec question - Exhaust manifold
    I was reading that the torque spec for an exhaust manifold is 23 FTLBS, How acurate is this as when i put on for 23, it litterally took nothing to tighten it... Also, the stock heat shield [<(HOT)>] was damaged during removal, is this a NECCESSARY heat shield?
    -Js
    90 Accord EX F22a1 Auto R.I.P.
    2011 Mazda 3 Hatch 2.5L GS sport HELLO!
    The heat shield isnt really important. plenty of people dont have them on. counting me lol
    My s13 Ride Thread>>><<<My Rx7 Ride Thread "What is power without control?"
    New people click here
      Ok now that that is out of the way, here is my argument - I have R134 AC setup (damn thats cold!) and it seeems that the lines are alot warmer cause of the heat off the manifold, is it ok? (its hot to the touch, but adaptable to hold, it wont burn off your skin kinda hot, and this is the line for the refridgerant mind you.)
      (spelling errors due to how tired i am.. .dang...)
        Bump - Also still curious on the gasket torque spec.
        -Js
          the high pressure line on an a/c system is going to be hot to the touch no matter...it's gas that is pressurized to upwards of 200psi I believe, it will cool a little in the condensor (the thing in front of the radiator)...it looks like a thin radiator for a reason too...cause it is a radiator (sorta).
          The low pressure side should be damn cold...the colder the better...sorta...it can get a little technical though. Either way...cold is GOOD...damn cold is REAL GOOD.
          As to the torque specs...as long as you are following a haynes manual or chilton or something reputable you'll be fine...just make sure you've got Foot Pounds and not Inch pounds...if you found them on the internet...don't trust them...if you heard someone or someone just posted it or something...best to just get you a manual and check it...trust me...you won't regret getting the manual if you do work on your car yourself.
          The heat shield has been debated...I'm not sure how effective a piece of metal that thin is to keeping heat away...but I guess it HELPS...if your a/c isn't blowing as cold as it should...I would not suspect that as a cause though...if your a/c is working fine...then don't even worry.
          ____
            the heat shields are good, but not really that needed. I know plenty of people that don't have them in their car. I still have mine, All it really does is kinda reflect the heat, But after a while the shield is going to get hot. But thats for long driving times and stuff like that. I personally still have mine, But its coming off soon.
              You know..you see engine rebuilds with either wrapped or non-wrapped headers...but no heat shields...higher end ones are always wrapped
              ____
                yeah just take the heatshield off
                  No they aren't; high-end builds using ceramic coated headers.
                  Michael
                    It helps a lot. It is dual wall steel, so there is a pocket of air in between. This acts as an insulator, keeping much of the heat inside.
