idle problem with h22
    now let me start with thanking everyone who answered questions i had.however i have read the posts about idle probs but need some clarifying,it starts and idles normal but when i drive then stop it jumps back and forth i read the thread on tightening the iac valve and ill try that but anyone else know any other things to check???other than that car is perfect no codes on dash absolute dream!!! also future knowledge for fellow noobs to engine swap change the friggin plugs before trying to start! haha later all
    smoke tires, not drugs.
    Check your High Idle Valve
    SOLD!!
    Boosted H22
    375whp 298 ft/lbs at 15psi
      high idle valve? is that iac? someone told me to disconnect the coolant line from either side of that and connect the lines together instead of through the valve
        check all your hoses for vacum leaks.
        Project EX Coupe Coming Soon...
        ..::Built not Bought::..
          well no luck still ladies i believe its tps anybody know an easy way of getting at that?
            FIT Valve.... that is what mine was.... idled fine until it warmed up, low coolant level does this as well!
              is that the valve directly under tb if so i tried tightening and my coolant level is good
