i took apart my dash board and try to cange the GAUGES but i broke the needle of the temp. and now the only thing working is the rpms, and the speedometer moves up i don't know what to do?
ok so i mest up!
How did you get the needles off, did you pry them straight up? Because if you did not, the needles may not be tight on the pins. Try replacing the needles, my local junkyard doesn't even bother charging me for them.Originally posted by 92dmI was actually just being a smart ass, and not really contributing to this at all.
Bought from: cb95spd
yea man those damn el gauges, ended up cracking the plastic face because i had to keep messing with those damn pieces that kept falling down inside the glue is crap. and I know how stupid it is the way they want you to slide the guages over the needles through that little hole. dont feel bad i had to remove and install the dash trim all of it about 4 times that day and then i finally get it right and crack the glass. was pissed now everytime i drive thats all i stare at.
