Show me where the window motar is (Pic)
    This morning I decided to tear open my driver side door apart to put a new speaker in and to locate the window motor, I can't find it
    Heres the pic just point to it or circle it! thanks!
    josh
    http://media.honda.co.uk/car/owner/m.../400/14-12.pdf
      josh
      IT sits just behind that cluster of wires bolted to the window regulator to take the motor out you need to remove the the regulator to remove the regultor you must first unbolt the window from it and remove the window then remove those six 10mm bolts holding the regulator unplug the harness from the motor and then manuver the hole assembley out of the bottom of the door. Hope that gives you an idea.
      I need a 14b or 16g turbo!
