ok i drive a 92 accord 4speed auto and when it goes to shift in 2nd or 3rd it makes the engine shake is it a motor mount and is it the front stunt mount?feels like the car shifts really hard...
motor mount
Originally posted by Dans92cb7i no the front is bad for sure...but aint the back...eletronic?
most likely the trans is going out.The beginning of a new era............................
The mount closest to the firewall on an automatic is vacuum operated it basically dampens the vibration you feel through the engine and trans especially at idle at cold start. It should really not affect while driving. I would inspect yourr other mounts and axles. Another way you can narrow it down to see if your trans is bad is to shift it manually see if it shifts differently on my auto if I shift it manually it shifts alot smoother than if I let it shift by itself. So I know my trans is on its last legI need a 14b or 16g turbo!
I would just check the mounts by grabbing a crow bar or pry bar and move them if they are moving excessively even though they look good they just might be mushy. Also does the engine move alot when shifting from park to reverse or into drive and again check those axles one could be bindingI need a 14b or 16g turbo!
my motor mount dose the same thing and i have to lut off the gass to lut it shift easy!!! but i have a Q. umm when changing the mount and unpluging the house toi the vacum.. is there anything i should do to it befor i unplug and remove it ..or can i just take it off and swop it out?? i dont wanna ruin anything!!! moneys tight you know!!
yeah i alredy replaced that moune..its just the rear mount i have left to do.. and i waz just consernd that if i just unplug the vacum toobing it would mess somthing up..but that just me being safe.. dont wanna runin the mount i got ..cuz i got that one bran new 9its the most important mount there) so i had to ..lol also ..dose anyone know the easy'et way to chang that mount ..do i have to go from under the car or can i simply do it from the top?
