My antenna and dome light doeosnt work. What could be the problem. The antenna doesnt go down anymore. Could it be a fuse? Also the dome light doesnt turn on when i open the door. Thank for the help in advance.
Antenna and dome light problems
the stock antennas frequently get stuck with age, and lack of lubrication. first tehy stop moving (click click click) then the motor burns out. as for the dome light, check the bulb, check fuses, and check the door switches... does the light come on with any other doors open? also, make sure the slide switch on teh dome light is in the middle.. if its to either side it wont come on at all or its set to on all teh time and the bulb is burned out
haha, yea this antenna problem happened to me and mine went out yrs. ago!! check to see if when it goes up or down it makes a "click click click click" sound when you turn the car on/off. if so, the plastic gear belt pully inside the actual antenna mast is broken from age. instead of replacing it, i just knocked the antenna down to it's lowest position and cut the wire for the motor. the motor had burned up too anyway.
for the dome light, check to see if the small door lights come on. if so, it's within the light (bad bulb, switch, etc). otherwise, i also had this problem sometime recently. it turned out i had blown a fuse that controls some random items (intermittent wipers, dome light, door lights). hope this helps.
the one under the hood. it says int. lights on the cover i think. it's a 15 amp fuse. i had a short after i put some lights in, mine kep blowing.Is God willing to prevent evil, but not able? Then he is not omnipotent. Is he able, but not willing? then he is malevolent. Is he both able and willing? Then whence cometh evil? Is he neither able nor willing? Then why call him God?- Epicurus
