Pulling codes and ignition timing question, ABS light on
    Is the two wire connector located in the lower pass side kick panel used to pull the engine codes and set the timing? Blue connector, green wire with white tracer and orange wire with red tracer. 1993 accord ex. My check engine is on all the time. I have disconnected the battery and that didnt reset it. My abs light is also always on, need help with that also. Thanks in advance........
    David
    davidsgould@comcast.net
    yes.
      Yup...short that wire conector with a paper clip and that will give you your code.
      MR Thread
      GhostAccord 2.4L Blog
      by Chappy, on Flickr
        Thanks for the input. BTW what is an A6 intake with injection and the exhaust manifold worth?
