its the pt2 ecu, but from what i read on here-its rare, but there are alternatives. just gotta do more research.
JDM F20a Swap
Originally posted by d112crzyI don't understand how you "break in" a motor that has over 30,000 miles on it already.
Unless you installed new rings and new bearings, there is no need for a "break in". Unless you installed a new clutch.
Originally posted by Cb7xChunits not so much as breaking it in, its just that im not sure how long the engine sat at the engine distributor. I'm gonna take precautions and won't get on it til i at least do my first oil change. make sure the engine is properly seated in the bay, all seals are properly lubed up, fittings and hoses are tight, etc. probably change my oil after 1500 miles, and 3k from there on. i don't see any harm in being careful with such a big investment, but i will get numbers back as soon as i can.
Nad Auto here I come
Originally posted by Cb7xChunI'm still running the f22a1 ecu, so i feel that it still has a lot of potential. As is the powerband is good from mid-range on up. Haven't been able to push it yet, still breaking in the engine. I'm probably looking to get another ecu properly tuned for the f20.MR Thread- I brought SEXY back- LOL
If it jams, force it. If it breaks, it needed replacement anyway.
Never argue with an idiot, they drag you down to their level and then beat you with with experience!!!
Try a H23 ECU, it's very similar to the f20- both DOHC non-vtech. It shold work well, but before you buy one**Blk Housed Slut Crew Member #1**
