90 ex rough idle
    90 ex rough idle
    hey everyone,
    new to site with a question. I have a 90 accord with 200+ miles. I'm having a rough idle problem. replaced plugs, wires, cap, rotor n still have rough idle. car runs great otherwise. anyone with same prob or fixes please help. is timing off-dirty injectors-?????????
    maybe your motor mounts are broken. if it isn't misfiring when driving, most likely the motor mounts.
      motor mounts
      thanks for reply. mounts are partially torn. how to distinguish between mounts prob n misfire?
        misfire will still make your car run rough with load. motor mounts broken will make engine rumble at idle. is your car an automatic??
          idls prob
          appreciate the input. no 5-speed. cleaned throttle plate yesterday, smooth for a few minutes. then back to rough.
            There is a screw in the throttle body that you can adjust. That well solve your problem.....
            I well have to look at my wife's wagon to give you better directions...
              Check for vacuum leaks and since your car is up there on miles I would just replace all the vacuum hoses there cheap and easy to do just make sure you do one at a time.
              I need a 14b or 16g turbo!
                1. smoke test if u have rough idle( idle is jumping around)
                2. carb cleaner around tb housing and listen to see if it sucks anything in or any where they can be a leak
                ps smoke test is the best way would find the leak real quick i had a problem too with my 92 lx
                dont change thing smoke test it dont throw money at a problem untill ur sure of it
                4 door ex-l
                  i had the same problem i changed my motormounts and cleaned out the throttlebody and took it on a 50 mile drive it was fine after that
                    mine
                    to have that problem but mine is more like when your at a stop sign or something and release the brake pedal and creep foward it jerks but i still cant figure it out everythings been from new vac hoses to cleaning the iacv 3 times
                      egr problem maybe.
