clicking sound when car is turning left, from right wheel
    my 90 ex is making clicking sound, when the car drives and u make a 70-90 degree left turn, it clicks until the angle is less than 70 degree, sounds like its from the right wheel
    i hear nothing when the car is running or turning right, but when doin sharper left turns, i can hear it, and i heard other cars on the road with that noise too sometimes, what is wrong?
    my rims cost more than my car
    need a new right axle. your cv joint is bad.
    1993 Honda Accord EX-R Coupe Granada Black Pearl
    ///Alpine CDA-9847 Head Unit
    OBX Pedals, stock air box, Ebay headers, Stock dual tipped muffler. Emblems removed, grill chrome painted black.
    1993 Kawasaki EX500 Flat Black. First Bike.
      bingo
      Please, Leave me some feeedback on my ride ^CLICK ^CLICK ^CLICK
      But Honda guys know EVERYTHING about EVERYTHING! If you don't believe that, then you're just wrong...
        yup
        you need a new or remanufactured passenger axle, just stop by your local auto parts store and get it for like 59 -100 bucks dependin on new or refurbished. might want someone to help you put it in, theres post on here how to do it to just use your favorite search section on here. its not that complicated either like a 30-45 min job with regular tools like a 32mm socket and a long or well leveraged handle breaker bar, some penetrating spray will help alot.
        OLD
          ^^^ Ditto^^^
            what everyone said. the cv joint gone bad. its best to replace the whole axle to have warrenty on it. mines clicks on the left side, but im waiting for my 5spd tranny and get manual trans axles.
            miss my turbo cb7
              Id say axle
                99% of the time its your CV BOOT best to replace whole thing. Soon Before you have to replace your wheel bearings too. Also check to see if your steering rack and Pinion "BOOT" is not broken. They click also.
                  any pics? i am not too sure what tat is...
                    wow. well when you take off your wheel . you look behind the rotor. and you'll see a big shaft connected to it and the other side connects to the tranny, thats an axle.
                    miss my turbo cb7
                      i might try the cv boot 1st, the axle... could burn a hole in my wallet
                        Yep should be the cv joint like everyone else said. Mine does the same exact thing. Like EMS CB7 said, it is probably best just to get new axles.
                          ok, more stuff to do...
                            You could be safe driving on it for a little while, but not too long. My friend waited to change his on his DA9, (which doesnt even run anymore ) and it drove like the the wheels were gonna fall off.
                              its too late to change the boot. i did the same thing, and it still clicks. get a axle from a junkyard.
                              miss my turbo cb7
