A/C fans not blowing strong
    I've always wondered this...my a/c fans dont blow quite as hard as other cars for some reason. I did have my blower motor replaced a couple years ago and that still didn't make a difference. All my fan speeds work. Reason im wondering is a 90 EX cb7 came into the garage i work at and when I messed around with it the a/c fans blew a lot harder than mine do. My fresh air/inside air vent button also gets stuck when i press it. Kinda like the motor doesn't want to open the vent for the fresh air when i press it so it sounds like the gears are grinding. So i just leave it in the inner circulation mode. so i really dont know why it doesn't work at max efficiency.
    damn I have the same problem. I was thinking that maybe if i recharge my ac it would get colder?
    vouches --> mj1220mj,Trickedaccord92, Maple 50175, Customlowz, 92lx
      this is a normal issues all hondas have this.
      when you turn on so if circulates the inside air, it is going to work harder. also this is the best thing for the a/c and it blows better this way.
      when you turn on outside air, it wont blow as hard, because the air pressure outside is slowing the fan down.
      when you use a/c, turn on the inside button and close all the windows. trust me, its fresh air.
      miss my turbo cb7
        thanx
          my accord had the same problem. wait still does ahaha
          vanillagorilla A.k.A glock22
          Then one day I meet a man,
          He came to me and said,
          "Hard work good and hard work fine,
          but first take care of head"
