Grinding when shifting into 3rd????
    ok so like the title says, sometimes when i shift from 2nd to 3rd it grinds and sometimes when down shifting from 4th to 3rd it grinds. but it doesn't do it all the time. has this happened to anyone else???
    bought from - b-bomb, Davids92Accord
    sold to - Old School, DA92CB7, F22Cb7Rid3r
    ^^ R.I.P. you will be missed
    hmmmmmmm
    yeah i had this same problem, the synchro is going on your tranny so i suggest you use the transmission fluid called synchromesh, you can get at autozone for $7 bucks its under the name pennzoil, if not you can go to a chevy dealer and get there synchromesh, it worked for me but if it doesnt go awya its time to replace those synchros
    OLD
      http://www.cb7tuner.com/vbb/showthread.php?t=81694
      This was just posted a few days ago.
        yeap..mine grinds going to 3rd when i push it.
        *Needs*
        -New shocks
        -Struts
        -Drop
        -Cleaning
        -New Tires/Wheels
        -New Window Tint
        -Alot more lovin'
          I think one or two people have this problem as well.
          Like stated, change your tranny fluid. My grind is so bad that not even the synchromesh worked. However, one can figure out how to shift into third without it grinding.
          It is the synchros by the way.
            ^^^ what he said
              sweet!! ill go out and get some asap! thanks
