Rear Engine Mount
    Rear Engine Mount
    im in the process of taking my motor and trans out but im having trouble getting access to the rear mount to unbolt it...do i have to take the intake manifold off to access it???
    A wise man sees failure as progress...
    it would be easier that way, is it auto or manual, if its manual its much easier. i just did my rear mount last weekend and all i did to access it sorta was take off the throttle body. it sounds harder than it really is, but you just need patience
    -sean
    Members ride 15.927 @ 86.76 (f22a1)
    Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
    Arcadia Green Crew #10
      oh wats good sean...yea its manual...but i learned that taking the motor and trans out is not that hard its just a long process when ur by urself...
        no sir, you only have to take the bolt out and leave the mount on the car.
          yea i meant the bolt inside the mount...but i got my motor out bout an hour ago...thanks sean but i didnt take the throttle body off...i had enough room...
            how many mounts are holding the engine in place? if you have a bad motor mount will it cause your car to shake alot?
              Possibly. There is a rear mount, a gearbox mount, an engine mount and the front torque mount. It is pretty hard to get a good look at the rear mount to see if it's worn. The engine will probably move excessively when you accelerate if it is gone.
              Members Ride Thread
                A tip for anyone that has an f22a6/h23/f22b/h22 intake manifold.
                Remove the upper plenum before taking out the engine. It will make your lives much easier.
                I've never really looked at an a1/a4 intake manifold, so I don't know if it's one piece or two. But if you can take the plenum off, then do so.
                  A1 intake is a 2 piece (lower runner/upper plenum just no IAB's) and the A4 is the same as the A1 i believe
                  -sean
                    i took the engine out without messing with the intake mani... it was pretty easy to me once i pushed aside all the vaccum hoses and sht...but i can say that u should have at lest three people with u...
                      rear mount = back pain
