im in the process of taking my motor and trans out but im having trouble getting access to the rear mount to unbolt it...do i have to take the intake manifold off to access it???
Rear Engine Mount
it would be easier that way, is it auto or manual, if its manual its much easier. i just did my rear mount last weekend and all i did to access it sorta was take off the throttle body. it sounds harder than it really is, but you just need patience
-seanMembers ride 15.927 @ 86.76 (f22a1)
Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
Arcadia Green Crew #10
Originally posted by jyoungblood87im in the process of taking my motor and trans out but im having trouble getting access to the rear mount to unbolt it...do i have to take the intake manifold off to access it???The beginning of a new era............................
Originally posted by JDM ACCORZhow many mounts are holding the engine in place? if you have a bad motor mount will it cause your car to shake alot?
A tip for anyone that has an f22a6/h23/f22b/h22 intake manifold.
Remove the upper plenum before taking out the engine. It will make your lives much easier.
I've never really looked at an a1/a4 intake manifold, so I don't know if it's one piece or two. But if you can take the plenum off, then do so.
A1 intake is a 2 piece (lower runner/upper plenum just no IAB's) and the A4 is the same as the A1 i believe
