reverse gear
    reverse gear
    i have a automatic in my CB7 and everytime i backup there is this grinding sound like my trans is rubbing the gear or its going out soon im not sure what it is
    fluids.. check em. or could be solenoids.
    1996 Honda Civic LX 2009-2012
    2012 Kia Optima LX 2012-2013
      i just changed it and filled it up wiht B&M trick shift trans fluid
        Was this sound happening before the fluid was added, if it was happening before and with you having an auto you might need to change the screen in the tranny and do a full transmission service. It's not hard to do. But other than that if the sound started happening after you topped off the tranny fluid it's quite possible you over serviced the tranny.
        "Wise people treasure knowledge, but the babbling of a fool invites disaster" Proverbs 10:14
          it was like this when i bought it so just change the screen and the fluid again and it should be fine
            It could be the fluid itself coz I heard other fuid brands than honda ATF will screw your Auto tranny.
            Like mine , I had changed on Pennzoil and it feels like the tranny has high mileage. But when I went to Honda to change it to Honda ATF if runs like brand new.
              okay how much was it?
                Honda charges $80 with tax.. if you wanna do it yourself you can get Honda ATF for $5 a quart.
                  okay do i have to go to the dealer or can i got to a auto parts store like autozone/o'reilly's
                    Honda ATF is only at the dealer. I heard DEXRON 2 is ok also. Im not sure.
                      Oh yea, that fluid makes a big difference. But you may as well change the screen/filter while you're at it cause i'm sure the car has well over 120k on it iand everything is probably original. Even if not so do it so you can can have a piece of mind and know that it's been properly changed out plus you can look for wear on the xmission.
                        okay i have a swaped engine and trans with only 100,xxx but the body has 251xxx on it but ill change the screen
