Idle Problem
    Idle Problem
    Lets make a long story short. I got into an accident so rather than buy a new car I took the engine out to put in another accord. Picked up another accord with a blown motor to put my old one in. I had the head off to be P & P along with an F22A6 cam and new valves. I also have the A6 Intake manifold on there with DC sports header and a Monza Hi-Flow cat. I finally got the engine started and have worked out all the CEL codes so now I have no Check Engine Light. The car idles at about 2k RPMs and when I pull the gas pedal back it drops down but then the idle continuously jumps between about 1k and 2k RPMs. I'm thinking I have a vacuum leak but i'm not sure. I'm wondering what you guys think it may be. Also I have an AEM short ram intake and for exhaust, there is nothing after the cat right now, i'm waiting for my Tanabe catback to come in.
    I also have to add that someone had cut the wires just before the dizzy and put these crappy quick connectors which I have replaced because that was causing the car to not start.
      u gonna check Fast Idle Thremo Valve n Electronic Air Control Valve....
      maybe it so dirty ot loose...
      hope it will help....
      Signature Picture removed due to excessive size
      VOLVO 240GL bandit crew....all mighty supertank
        Will check those in the morning thank you so much
          try playing a bit with the IDLE ADJUSTMENT SCREW that's what helped me before ! That is if you do not have any CEL codes and that's the case I think ?
          You know kid...some day this war is gonna end (sob)... C.O Kilroy (Apocalypse Now)
            I messed with the adjustment screw and nothing happened at all and you're correct, I don't have any CEL codes.
              Yea dude, go back and check all your vaccum lines, especially the ones on the t/b, check the PCV on the valve cover, and the FIT and EAC. But it really sounds like a vaccum line is off or maybe has a slight tear.
              "Wise people treasure knowledge, but the babbling of a fool invites disaster" Proverbs 10:14
