Lucas additives
    the power steering additive works. but i had a hole in my cv boot and i was lazy and it was already rebuilt i didn't want to take it back out. but so far the lucas power steering additive works but i dunno aboout the rest...
    either kill it or drift it...
    2002 Toyota Tundra V8
      so lucas is safe to use in the power steering and such items ??
      also do octane boosters work, and gumout MPG increaser or some crap ?
      Members Ride - 1993 Honda Accord EX
        lucas oil was really made for like v6 or v8's. my opinion only.
          Lucas is meant for any engine, similar to Slick 50 (Slick 50 far superior in my opinion) it creates a almost no drag on the engine parts.
          The Lucas is heavy crap, it actually slows your engine down somewhat. In small amounts it is benficial, use what they tell you and its too heavy.
          Slick 50 is what you need. The military uses Slick 50 in the military Hummer and other military vehicles. The entire engine is coated in teflon, which is insanely slick. Now the reason the military uses Slick 50 is that when the oil pan is broken or the block cracked and all the oil is gone, the Teflon is there and the engines wont cease for days and days.
          Search around and you can find a Slick 50 Briggs and Stratton engine that ran for 5 years without oil...
          Your man for wiring solutions!
          CB7Man's Coupe H22 Swap
          CB7Man's Sedan Resurrected From The Dead
            hummer engine vs. honda engine.??
              The standard hummer 6.9L Diesel engine will cease in the same time frame if not faster then the honda engine...simple size comes into play there.
              Slick 50 works so well that some people have clogged their oil ports and such from useing it too much, thus it starves the engine of oil, so only use it once in a while.
                good point.
                  Actually the military humvee is either a 6.2L or 6.5w/wo turbo(armored). Also Just because they use it, dont make it right. Military likes to cut corners sometimes.I know from experience.
                  I've serviced a sh*tload of humvees(mechanic in the army reserve) and not once were we told to use slick 50. When we were down range under the one of the worst conditions for these vehicles, all we ever did was change the oil regulary. Slick 50 is all hype man. So is Lucas. Slick 50 is a very old formula and it uses what we should never put in to an engine, Teflon.
                    Wow another person that knows what hes talkin about. IMO Additives are pointless and just a crutch I guess you can say. If the manufacturer thought additives were necessary why didnt they include it in the manual. Think about it. In a good world if you do all the proper maintenance, keep up to date with your car you shouldnt need to use additives.
                      additives
                      this is true....there is alot of hype about them....if they were meant for constant use, the owners manual would have a listing for it!
                      Nitrous is like a hot chick with a STD..... you know you wanna hit it, but you are afraid of the consequences.....
                      ...Zex wet kit, 65 shot, dual purge, JDM H22...pure sex! .....I owned 8 CB7's in one year...top that JARHEAD...lol
                      ...this thread has been graced by the new CB7 King
