hi could you guys help me when i'm driving i keep hearing a loud sound and when i drive even faster the loud it gets so i dunno whats wrong so could anyone help me =p thx in advance
loud sound when driving
Sounds like a wheel bearing to me. Make sure nothing is dragging around the tires. Is it a humm?
Does it get quieter or louder as you turn? Wheel bearings generally make a howling/growling type sound. When you turn you are slightly unloading one side of your car and loading the other. So, if you turn left and it gets louder then its probably your right hand side wheel bearing. and vise versa.
Also, most suspention shops will do free estimates, have them put it on the rack and diagnose everything then take it home and fix it yourself. The wheel bearing requires a press i belive, might be a little beyond most backyard mechanics. But if you remove the whole hub assembly and take it to Napa, they will press the bearing out and the new one in for a nominal fee.
-Yoss
jack up your car if you have play in the 12/6 (push pull the tire) o clock position your wheel bearing is gone. You can see if anything is dragging around the brakes causing the noise as mentioned.
Originally posted by jle2ko ok cool thx and play is like movement right?
how did it go? no play?
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
