mods?
    mods?
    i have a 90 accord lx with a ex swap what are the best mods to egt 200+ hp i already have apexi n1 style exhaust and injen ram air intake any suggestions will be appreciated
    H22A
    wat?
      turbo set-up
      1996 Honda Civic LX 2009-2012
      2012 Kia Optima LX 2012-2013
        if you don't want to have to tune a car, ergo losing potential for more power later without changing your set up, then swap the motor.
        if you don't mind a little tuning then boost it. you should be able to buy a kit or piece one together yourself for cheaper than the swap, and it can grow as your power needs grow as well...just a greater chance of going boom.
          i like NA setups you dont have to worry about burning out anything is it possible that a b20b will fit into an accord? my bro has 1 in his integra
            i would go h23 ar h22
              im pretty sure u actually lose power when swapping to a b20b i could be wrong tho
                anything can be done with enough time and money
                you are looking at a civic with an ls1 in it...so im sure you could get a b20 in the accord. lol this is real
                  i think ill go with a h22 with 4-2-1 header and the apexi exhaust and injen intake with a jdm trans
                    but the b20b has alot more torque than a usdm prelude motor and you can always build a b20b up like u can a prelude motor
                    h22-160hp stock 130ft/lb torque
                    b20b- 140 stock 145ft/lb torque
                      i could be wrong but i think those numbers for the b20b r a bit high, but i could be wrong and it depends on which h22 u get as to how much power you get bc those varied through the different markets/years
                      are you going to school at usc?
                        it may be but thats wut my bro is making with exhaust and intake no i dont attend usc im in highschool still just working to fix up my car to get some custom mods i wont do an engine swap until next year
                          my bad the b20b stock is 126hp 133ft/lb torque but intake and headers and exhaust help
                            ok well i was going by stock numbers... stock vs stock the h22 produces more power than the b20b... if you are gonna do a swap then i wouldnt do anything that you cant utilize with the new motor, no sense in throwing money away... but thats just my opinion... its good to see another south carolinian on the board
                              yea i know there arent that many south carolinians on the board but im thinking a h22 or h23 would work out fine h22 190hp / h23 160 hp
