Belt Change
    Belt Change
    I am planning to change my power steering belt and want to know if any body and a quick write up of it
    im guessing its just like any other car... you loosen the tensioner, its a bolt that you turn until the belt loosens and then bam you take it off... its probably one belt that turns everything... and you can take that belt to any parts store and get a new one... then just put the new one exactly as the old one came off making sure to tighten that tensioner bolt until there is very little play in the belt.. someone correct me if its different
      its pretty easy to do it, 1st there is one belt for the power steering and another belt for compressor and alternator. Take a look at the DIY section and you will find how to change the alternator belt pretty much the same.
      Click Me
        http://www.cb7tuner.com/vbb/showthre...&highlight=ENG
        Same process with ps pump.
          k so its 2 but its still the same premise
            Bolts are located in the same area just around the ps pump. Same size tools also.
