Turbo my CB7
    you can put the new fuel pump in (walbro 255 ) before the turbo
    but you CAN'T put the injectors in before the turbo goes on. you will run way too rich.
    BB2F22-T3super60:250hp/275lb-ft @10psi
      i am running the setup you want right now and your best bet is to get a namebrand turbo there you are safe. i got mine from turbocharges.com there is a good price and you get a warranty. As for the injectors wait till you have all your parts. there is no point in putting them in now. And once you put the injectors in you need to go get it tuned asap. untuned motor= blown motor. do some research. But don't go cheap do it right the first time. If you have any other questions i will gladly assist you the best that i can
      ~Nick~
