heey for some reason my steering wheel starts to shake once i past 70mph. at first i thought it was cuz my windows were down but i tried it with all windows up and it still does it? wtf is up widdat? does anyone else accord do that?
Steering wheel problem
Possibilities.
- warped rotors
- unbalanced tires
- uneven wear on tires
- worn suspension bushings
- loose , worn or damaged suspension parts.
1996 Honda Civic LX 2009-2012
2012 Kia Optima LX 2012-2013
hey mate, chances are that when your wheels are unbalanced or not properly aligned, unless its under brakes and that opens up more possibilites, like warped or disfigured rotors, but i reckon it will disappear after a wheel balance and alignment.
Take it easy"Am i crazy? Or am i so sane that i just blew your mind?"
same problem happened to me....when i accelerated on the highway up to about 65 or higher, my whole car used to shake. well it might be your cv axles. check to see if there is any play in them or if any of the boots are ripped. even if the boots aren't ripped, they might have play and thats what is causing your shaking.
all right if you car shakes at 65 and goes away after that. balance your tires and keep your tire pressure consitent.
my car does the same thing fro 65 to 70. i balanced them and it is a lot better. it is still noticeable but not nearly as noticable as it was before. im picky too.
manufacture specs for tire pressure is 29psi. before going on a trip make sure its at 29 and by the time they warm up they will be inflated properly for highway use.
every 10 degrees higher = 1 Psi increaseword...
