93 Accord Won't Start
    93 ACCORD SE AUTO
    I've replaced the Main relay and it seemed to temp. fix the problem of not starting. However, it has not started in 3 days. It turns over but does not start. Please give some advice. Thanks.
    check all your grounds and is it getting spark? is it getting fuel?
    kms-fab.com repin the 513
    tuned1.com
    sleeperautosports.com
    i will build another frank
      Fuel, spark, compression. 3 easy things to check if you have a no start. Well compression is a bit harder but fuel/spark is easy.
        After I put a new Main in I tried to start it and I got sort of a start and then nothing...nothing at all. No instument lights and won't even try to start. It's like the battery had been disconnected although I have headlights, horn and etc. Please help. Thanks.
          Check your thermostat ground and fuses.
            Ignition Switch
            If your ground and your fuses are fine, and if you can smell gas when you crank (getting fuel), and you have spark,
            If it seems like you have power (headlights, horn, etc), but no instrument lights and the starter isn't even cranking now,
            then check your IGNITION SWITCH:
            http://www.cb7tuner.com/vbb/showthre...nition+removal
            My Ride (Click here)
              Folks,
              Thanks so much for the help. It turned out to be the IG (Ignition) 50A fuse under the hood. Thanks again.
              Bob
