Brake Problem
    Brake Problem
    Yo! Sup peeps! I need some advise people....my brake peddle and my brakes started acting up.....my brake peddle when pressed gets extremely tough to step on and my brakes don't activate......has this happened to anyone else before?! What do you suggest it might be?!!? I checked my fluids and they are topped off....and I don't see any smoke coming from the exhaust when I press the peddle......no brake fluid is on the floor either.....any suggestions?!?!? Hook me up with your info as I want this for the July 28th meet which is around the corner.
    Thanks!
    Heck
    My 1990 Honda Accord! [B]
    No major mods..16" aftermarket rims with 40 series tires...tinted windows...CB7!!!
    check your caliper slide pins. they might be seized up or something and thats why they piston isn't moving back and forth. so just take off your wheel and there should be 2 12mm bolts holding the caliper on, just take them off and inspect them, they should be greasy somewhat, since those are the slide pins which the caliper moves back and forth on
