So heres my problem. My sport mode engages when it wants and if i push the button, it wont do anything. It will stay on and wont go away. its really weird. I guess I could check the code if one shows up. Does anyone else have this problem orrrr knows something else I could do if there is not a code?
Sport Mode stays on without button engaged
Best bet is to jump the code find out what its throwing then work on it from there.
Originally posted by pandaaccordIm not trying to sound stupid but i have never seen this sport mode thing that everyone is talking about.Is it on automatics only or is it only on special models of the accord???
Flashing Sports mode light means VSS possibly crapped out.
Does your car change gears w/out problem?91 EX F22A4 - Stock w/ 220k mi
My Ride - 12/06
naw its like random random days it will just be on and stay in either in 2nd ooorr 3rd gear and not turn off. it will turn off after 3o min of driving and thats it. The
button wont turn it off or even turn it on.
BTW: Sport mode is only on automatic transmission hondas during 90-91 i think. Its basically overdrive just called sport mode
Glad that I found some info on this. I was also new to this "sport" button b/c I had a '93 which didn't have this feature. Currently, I've been building a '91 Accord from the ground up and here's my situation and question:
I switched over the whole shifter assembly from my '93 with the exception of adding the shifter knob from the '91 (w/ the sports button). Everything is wired in and looks like it should be in working condition but I want to make sure everything is in order before it's on the road one day. My main question... is this even possible to incorporate the shifter knob into the '93 shifter assembly? If so, would I need to transfer and ECU's, swap any codes, etc?
Another problem that confuses me... sometimes I'll get into the car, start it up, brake pedal depressed, and won't be able to release the shifter into other gears (it's and AUTO). I'm familiar with the release on the right side of the shifter when you press the brake to release the shifter to shift into reverse, D4, D3, etc. Just @ random times, it doesn't work and it's just tedious and annoying to have to pull the key out, put it in "shiftlock release." After that point, it works fine until it won't release from park again. Thanks for any help with these issues.
