I have some tokico blues i bought of my buddy, but i wanna upgrade to some adjustables. AGX's seem like a good idea but i heard they kill your drop... I have H&R sports and i was wondering how much they will add to my ride height over the blues. Or should i spend they extra hundred and get illuminas, Konis are just to much for me...
Thinkin of buying agx's but...
Originally posted by twokexlv6coupekill your drop?? what do you mean?
had my agx's with neuspeed race's for about a year and a half now, plus about a year on neuspeed sports before that with no problem what-so-ever
Compare my car to owequitit's for a good example. We have the same springs, same wheel/tire size and offset, and just different struts.
I had a set of AGX's on Neuspeed race springs(rated for a 2.2in. drop) and the drop left me with a 3 finger gap all the way around.( I have 17's sitting on 40 series tires.)
It's a great stiff set up, a little too bouncy for me though so I switched to Tokico HP's and Neuspeed sport springs. It left me with about the same drop as the AGX/NeuRace set did.
Thinking back I wish I had gotten the Illumina's. I miss the adjustabillity.3 CB's gone....
1 WK Overland....
Still miss the CB though......maybe one day.
check the sig, thats KYB agxs and h&r sports i like the drop, i dont have to tip toe around bumps and shit like people that are super slammmed, i think after a point it starts to hurt performance being so low
-seanMembers ride 15.927 @ 86.76 (f22a1)
Hit the clutch Hit the gear Hit the gas and i'm GONE>>>
Arcadia Green Crew #10
I don't have to tiptoe around anything either.
In my experience AGX + those springs = rides like crap.
I would get the Tokicos.
And my car is noticably lower than AW's.
Plus the fact that the one guy above me said the AGX's and the Race's were about the same as the Tokicos and the sports...
Neuspeed Races with Tokicos tuck tire.
Originally posted by owequititPlus the fact that the one guy above me said the AGX's and the Race's were about the same as the Tokicos and the sports...
Or am I misinterpreting what you said?3 CB's gone....
1 WK Overland....
Originally posted by 91Accord-LXI have Neuspeed Sports on Tokico HP's not Race on Tokico HP's. I don't tuck tire.
You misunderstood what I said.
Was it you who said you had races and AGX's, and it was about the same as Sports and Tokicos?
If it was, then my point was, if you put those race springs on your Tokicos you would be tucking tire, not level with a set of sports.
There is a LARGE difference between the 2. Go look at ray ray's old Accord, if you want to see what Races SHOULD look like.
There is a LARGE difference between the 2. Go look at ray ray's old Accord, if you want to see what Races SHOULD look like.3 CB's gone....
1 WK Overland....
I have this exact same set up on my car.h&r sport springs and agx's. the ride is really comfortable compared to my homies car that has the same shocks but eibach sportlines. his is more bouncy than mine. and the drop isn't that bad, at least to my opinion. it's got about I think a 2 almost three finger gap on 16 inch rims with 50 series tires.The beginning of a new era............................
Eibachs are notorious for being harsh. H&R is decent... 93twodoorLX has my old setup. I'm on H&R Race and Koni Yellows now, and even though I'm lower, the ride is actually better. And the adjustability of the Konis is far superior to the AGX. You can go very soft, and you can go go-kart stiff. Well worth the additional investment, IMO.
A full coilover system is also a good idea. They can get expensive, based on the quality, but a decent setup is no more than a good set of springs and new Konis. You don't need a $2000 coilover setup for a street car.
One thing to keep in mind with coilovers is that once you set them to where you want them, get an alignment. If you ever change your height, align again. A $70 alignment is far cheaper than a new $500 set of tires! That's one reason why I like springs... I'm set at that height, like it or not!
